how long till solo after landing?
I could be wrong, but this if so, I'm sure someone will correct me.
- Pull up into a vertical climb, then reduce throttle until the plane stalls.
- Apply a short burst of throttle to get airflow over the rudder, and apply full rudder to one side
- Neutralize the rudder when the plane is pointed straight down
- Once plane reaches sufficiant airspeed, pull out into level flight (prefferably before you reach the ground).
I think this is also called a hammerhead???
