RCU Forums - View Single Post - Cox .049 Cast Engines
Old 12-02-2008 | 08:31 AM
lukesp's Avatar
lukesp
Default RE: Cox .049 Cast Engines
Cent,
if they are the last of the Cox offerings, i.e. from surestarts with the cast crankcase then you will find the crank is a sloppy fit in the bush. According to Dan Sitter these crankcases are Chinese made, the earlier Dragonfly cast crankcases were a better fit although I can't remember where he said they were made. Dan sells or sold the original c/cases on ebay as coxmania. So if you bought em from coxmania they should be good.
Luke.
