ORIGINAL: eminentguitar
ORIGINAL: fernandorussell
Hey guys, im not of big fan of greasing the differencial ring and pinion b/c i just flings off and accumulates around the diff case so i wanted to know if it would be ok if i just fill half the diff with 10000wt or some other diff fluid so it will always be lube.
thanks.
Grease stays on just fine as long as you use a good silicone grease of anything really good I guess. All they say to do is put a thin layer on the ring gear and away you go.
From what he is saying is the ring and pinion and if I understand what he is saying there is no way to fill with oil as it will leak out fast. I do not think hes is talking about the spider gears in the diff cup.
