RCU Forums - View Single Post - engine temp help
Old 12-02-2008 | 10:36 PM
Fuelman
Default RE: engine temp help
ORIGINAL: hoochie187
Hi there does any one know what temprature a force 25 engine should run at, cause i cant seem to get it lower than 260, even richening the hsn, seems to still go up in temperature. Anyone got any advice, it is brand new and i am breaking it in. Thank you
There is no definate answer to "what temp". What one person thinks is the appropriate temp for your engine to be at may be different than yours because of so many variables.
Fuel, plug, air temp, altitude, humidity, gear ratios, etc.... all have influence on how hot or cool an engine runs.
Your engine will never be too hot if you do not tune it too lean (assuming it is getting adequate air to the heat sink). Basicaly put, if you tune your engine so that it does not have any lean symptoms, and you have it tuned for crisp and clean transition, you will not have a lean run (due to tune).
