RCU Forums - View Single Post - Official HPI MT2 Thread
Old 12-02-2008 | 11:31 PM
  #18483
eminentguitar
Default RE: Official HPI MT2 Thread
ORIGINAL: 46u
ORIGINAL: eminentguitar
ORIGINAL: fernandorussell
Hey guys, im not of big fan of greasing the differencial ring and pinion b/c i just flings off and accumulates around the diff case so i wanted to know if it would be ok if i just fill half the diff with 10000wt or some other diff fluid so it will always be lube.
thanks.
Grease stays on just fine as long as you use a good silicone grease of anything really good I guess. All they say to do is put a thin layer on the ring gear and away you go.
From what he is saying is the ring and pinion and if I understand what he is saying there is no way to fill with oil as it will leak out fast. I do not think hes is talking about the spider gears in the diff cup.
I know man and another thing about the thick 10k oil is if you ever did put that in your diff housing for the ring and pinnion it would really effect your performance alot..... in the diff cup now thats a different storey.
