ORIGINAL: fernandorussell
Thanks, I'll stick to silicone grease for the drive gears.
What oil Wt do u guys use in your diffs if any, if not, what you you recomend.(this is to fill the frnt and rear diff case with)
thanks.
I just use grease in everything there not sealed that well so I think oil would just come out even the grease comes out
