RCU Forums - View Single Post - Nitro Planes EDF Pre-Maiden Procedures
Old 12-03-2008 | 02:22 PM
  #38
opjose's Avatar
opjose
Default RE: Nitro Planes EDF Pre-Maiden Procedures
No not as you are describing...
The two surfaces are already there, the problem is that they are linked to the ailerons, which makes the plane behave much like a delta wing plane, while it really isn't a delta wing plane.
Adding the two servos gives ( proper ) independant control to the elevator so you can do things like hold the nose up while the plane rolls... something you cannot do with a delta wing easily.
