RE: Selfmade smoke unit
3 thou piano wire will work for a filiment as well just heat it before you try to wind it around a wick as you need to remove the temper from it to soften the wire and make it long enough to get warm not red hot or you wont have to worry about smoke you will have a bonfire instead the wire will need to be 6 inches long
