ORIGINAL: dicko
ORIGINAL: Supervee25
What about 2 2cell lipos?
That's what I'd recomend, 2 x 3S lipos will fry your electrics, the esc isn't rated to 22V. 2s 5000mAh with a 25 or 30 C rating would be ideal.
2 3s lipos is SERIES will fry it. I recommended that he run them in PARALLEL. Series adds up voltage, parallel is for capacity. If you run 2 2s lipos in SERIES you will fry the internal BEC of the ESC unless you unhook the internal BEC and either get a Rx pack or an external BEC. Running 2 5000 mAH 3s lipos in PARALLEL should give you 10-15 minutes of run time.
