RE: Help with 31cc Ryobi conversion
Hello Again!
Forget the HELP I found the problem. When I took the weed wacker apart I didn't look where all the fuel line were hooked up to and as I have been trying to start it, I had the pump bulb between the tank and the carb. It needed to be on the other end of the carb so it sucked the gas into the carb and not pushing it in to the carb. After putting pressure into the carb it would run till the pressure was gone and had no way to suck anymore fuel into the carb threw the pump bulb which acts like a one way valve.
Mike
