RE: MOTOR PROBLEMS!
I believe his engine is NOT inverted, it is mounted with the head at a downward angle to one side instead.
I run most of my engines inverted, and all I do is replace the regular glow plug with a "long" plug to keep the element from fouling with fuel.
I've tried IDLE bar plugs ad-nauseum, but I get much better results with long plugs instead.
