RCU Forums - View Single Post - best method to land 90 size pattern plan
Old 12-05-2008 | 03:49 AM
riot3d
Default RE: best method to land 90 size pattern plan
ORIGINAL: selnekav
Hi
I find in very difficult for me to be able to control both rudder and slight amount of throttle on my YS-110 any small change in the Y stick movment can pull the model back to the air... do you use expo on the throttle ? or do you use switch for fast idle ?
Do you fly Mode 1 or 2, does your throttle has a ratchet? Regardless, since throttle and elevator is on two different sticks, one should not affect the other.
Just keep practice.
Adrian
