RCU Forums - View Single Post - Clipped Wing Senior Telemaster?
Old 12-05-2008 | 12:05 PM
Balsawings's Avatar
Balsawings
Default RE: Clipped Wing Senior Telemaster?
Here are pics of a Senior Telemaster ARF I built for a friend. Cut the cheeks and motor mount off of the firewall and mounted a Zenoah 20 directly to the firewall. I did reinforced the firewall to handle the extra weight. Ended up with 6 oz of lead in the tail to balance out the extra weight up front. Also, changed the wing to a bolt on affair.
It flies fantastic at 1/4 throttle and occasionally use 1/2 for loops. The plane is being used as a trainer for the 13 yr old son. He loves the plane.
I'm getting ready to build another with the exact same set up for another friend.
Bob Cox
SPA 374
Miami, FL
ID:	1084202   Click image for larger version
ID:	1084203   Click image for larger version
