RE: 2nd time DX6i has lost its bind.
Ok, I'm good with the binding now can you tell me what RX battery voltage should I stop flying at ?
I made a setup for my volt meter where I wired a 4 AA cell flashlight bulb to add a load when I test the RX battery.
I have a volt watch mounted on the plane but Its so cold out now I'd like to also measure the voltage between flights.
I'm using a 1700 mAh 4 cell battery in the plane. Would the " no more flying " voltage be higher because I'm using the Spektrum???
Thanks again
Steve
