A little is a lot!
When I adjust the low end idle screw on my 46FX I have found that it takes VERY LITTLE movement of the screw head to make a notable change in engine performance. I tell people to just "lean on the screw a bit", even a 1/8th turn seems to jump past the correct adjustment on mine. Good Luck
