AHA - Sales pitch
Ok, I have an open mind. Have your friend tell us how his product is better than or why Epoxolite is not a good choice to join wing halves. Also supply information as to ordering the material. Looking at the pictures of the reviewer using Epo-grip it did not seem to me that it was much different than Epoxolite.
What follows is a statement from a gentleman at SIG:
I Am not familiar with Epo-Grip, so I have to rule out any comparisons. However, Epoxolite is epoxy glue based and can be used as a filled adhesive although I have not used it in the situation described in the review. Epoxolite is very viscous so it needs to be manually spread like butter on the joining surfaces including the inside of the spar boxes. Properly applied it would eliminate any voids and slop between the wing halves and make a very solid joint.
Maddieone
