RCU Forums - View Single Post - best method to land 90 size pattern plan
Old 12-06-2008 | 12:10 PM
tIANci's Avatar
tIANci
Default RE: best method to land 90 size pattern plan
ORIGINAL: selnekav
Thanks !
Is there way to avoid shorten the ground affect that keep the airplane flying on 1-2 feet hight ? my airplane can fly on idle for above 100 feet on that hight.
Its called the throttle, throttle gives you lift, no lift no fly ... easy? Remember when you are landing the throttle controls RATE OF DESCEND and the elevator controls SPEED. Meaning you flare (you use the elevator to flare a plane) your plane to slow her down (causes more drag), if at that point in time she is descending too fast then give her some throttle to hold her up. That is the same principle as how you perform a HARRIER for 3D.
Like some have told you, come in with a pattern plane with a steep angle and she will speed up, come in shallow and she will be manageable. Its like when I first landed a EP pylon plane, the fuse is so sleek that it retains a lot of energy and if you dive, she picks up speed.
