RCU Forums - View Single Post - Engines
Thread: Engines
Old 12-06-2008 | 08:26 PM
rgm762
Default RE: Engines
sorry, but I can't resist, did he also tell you that while flying the wind chill will cause your engine to freeze up and your plane will fall out of the sky?
the main thing is that in order for your engine to run correctly, is that it reaches a certain "internal temp", hence the good previous advice on good fuel, letting engine warm up, retuning the engine and hotter glow plug. cold air will not cause extra wear.
