RE: ed New Here
If you are in the least bit serious about having a turbine aircraft you aare going to need a computer radio to begin with and this alone will decimate your 200 dollar mark. the advantages to having this type of radio is that you will not be buying another radio that you will outgrow rapidly. computer radios can be programmed to run several different planes with there unique trim and servo settings. buy a radio in the 9 or 10 channel range for extreme advanced aircraft.
