battery question
i can't figure out what the mah vs voltage on a battery pack means. I've googled and found all this info on amps, watts, ohms and voltage, but i still can't seem to grasp it.
what does the voltage rating mean? The higher the volts of the pack = the more power pushed to the motor? and what does the mah rating mean? the higher the mah = the longer the battery will last?
if there is another post with this information or a webpage somewhere that explains this, please link me. i was not able to find one. thanks!
