Chemie,
Check this posting and the next one on this thread post #44:
http://www.rcuniverse.com/forum/m_65...ey_glue/tm.htm
You can run the same test applying titebond from the side to see where the fracture is.
what im trying to say is either way assembled and applied from the side or applied to the bonding surfaces Not the glued parts are braking.
My suggestion is not to apply too much titebond glue to strengthen it because its hard to sand.
I’m using 99% titebond when its written to use CA and its fine, use Q-tips to spread it and hobby syringes.
Alex
