ORIGINAL: RC_Pattern_Flyer
Just curious how many have flown this sequence with Electric?
I want to know setup and mah used for the sequences.
Thanks in advanced.
Chuck Hochhalter
Hi Chuck,
I started playing with it in October after the contest season ended. In Michigan, that means generally cold and breezy. Anyway, I fly an Integral that weighs 10.5 lbs with a Hacker C-50 14XL Comp with the matching Comp controller, FlightPower 5350 F3A batteries, and an APC 21 X 14.5 prop. I always go through the schedule once and then land with no extra maneuvers. I typically used between 3200 and 3900 mah per flight which was real consistant with what I was using in the 08 schedule. Some guys are reporting shorter flight times and less mah with the new schedule but I found it to be about the same or slightly longer. Hope this helps.
Verne Koester
