ORIGINAL: Popriv
If you can tell what I'm trying to do by my description, stall turn?, hammer head? ??? here are my questions:
As I pull up to start this turn I add throttle. as soon as I go vertical I back off on the throttle and hit full left rudder. The plate rotates and when its pointing straight down I add throttle and follow the same path as when I came into the turn....
I'm not sure when to back off the throttle and when to add full rudder. I was very inconsistant, some turns looked great others it wouldnt rotate...
Any help?
Steve
Steve:
Check these links:
http://www.masportaviator.com/ah.asp...&ID=30&index=1
http://www.troybuiltmodels.com/newsi...ce.html#hammer
http://www.scootworks.com/rdrc/
Regards!
