Well I'm not sure if the other Failsafe or SmartSafe, whatever they're calling what.... works with the module systems?
I think that is part of what makes the ModelMatch feature work on the native systems but I'm not sure. Anyway, what you do is to put the rx into a bind mode and when the lights start flashing you pull out the bind plug and they should stay flashing. Then you turn on the tx with the button depressed and it's supposed to set all the servos to a signal loss position. Get online at Horizon and take a look at the X9303 manual, it's in there somewhere but I don't remember exactly where as I don't use that option.
Now, realize that there is a difference between where the rx puts the servos on power up vs. what happens on signal loss, not the same thing. Binding the model after setup dictates where the servos go on rx powerup and before it links to the tx, not where they go on RF signal loss.
Does that make it clear as mud????
You can PM me if I've just confused the issue.
