RE: DX7 Fail safe
ZEEB - Thank you for encouraging me to read the SPM Air Module manual. It reiterates what you have so kindly said.
I have apparently been Binding my Tx to my Rx and then removing the Bind Plug. This is the process for Hold. If my Gear Switch is Up, when I Bind this way, the Gear will Cycle whenever I power up the Tx and Rx. If I Bind with the Gear Switch Down, the Gear will not Cycle the next time I power up the Tx and Rx.
If I follow the Bind process, for PreSet, and set the PreSet, for Gear, to be Up, will the Gear still Cycle when I power up the Tx and Rx? They do not cover this in the manual.
