Engine mounting orientation
Most of the big engines I have mounted on that size aircraft were mounted inverted. Primarily so that the carb intake was on the side of the aircraft and easy to get to. Side mounting the engine would either place the carb on top or bottom of the cowl. On top hard to get to. On the bottom you don't want to go there.
Gas engines don't care if they run inverted.
Hope it helps.
