ORIGINAL: JoeAirPort
DL says you can use Amsoil Saber 100:1 after break in. Just like DA.
Why being so greedy with oil? If you use synthetic oil you don't carbonate the engine like using petroleum based oils. More oil never hurts. Your engine just thanks you with prolonged life span. I run all mine with a minimum of 40:1, some even richer. Just because you can run it lean on oil doesn't mean it is a good thing to do.
