RE: Drilling holes for robart hinges.
How far do you reassess the hinge pin (or elbow) after the hole is drilled. Does anyone have a recommendation for this method. Also I see the manual says you only need 2 ribs on the hinge for contact (you can cut the rest), Is this recommended. Thanks
