RE: Power Expander or not -that's the question
I'm getting ready to start a 33% TTOC Yak with SF PE Sport(I think), dual 2600mah Li Ion/switches& regulators. I'm still not sure how much current the 8 7955TG's will draw, even though Hitec says 2 amps each. If my set-up only has 8 amps total battery capacity(4 amps each battery)wont I be seeing large voltage drops? At 2 amps each, thats 16 amps, more than the batteries could sustain. Yet, this same set-up has worked for a friends 35% planes?? There is something I'm missing here, I can only assume that 2 A rating is assuming very heavy loading(large surfaces & speed)??
