Originally posted by David_Moen
B]Now put the servo arms back onto the servos with the arms at 90 degrees to the servo case.[/B]
Everything David said is correct except this. The servo arms should be 90 degrees to the pushrod. That may or may not be 90 degrees to the case. If the arms are not 90 to the pushrod then you'll introduce differential control movement.
