Hey guys,
I am putting together a 3D plane, and I would like your input. I have each componnent selected, and I think it should work. I just wanted to run it by you guys to make sure I didnt overlook something.
Fancy Foam Edge 540
http://stores.homestead.com/fancyfoa...k?sfs=63157231
Motor:
Specifications: A22-10S
RPM / V(Kv): 1200
Battery: 3 Lipo
Operating Current (Amps): 4-13
Peak Amps (15sec): 16
Servos:
Size : 21x12x22 mm / 0.74x0.42x0.78 in
Voltage : 3v ~ 6v
Weight: 9g / 0.32oz
Speed : 0.12 sec/60(4.8V)
Torque : 1.6 kg-cm
ESC: 30A ESC
22 grams
Battery: Zippy 1500mAh
Voltage: 3S1P / 3 Cell / 11.1v
Discharge: 20C Constant / 25-30C Burst
Weight: 138g (including wire, plug & shrink wrap)
Dimensions: 100x34x21mm
Prop: JM 9X4
I am worried about the prop- not sure if it is adequate for the motor
Any suggestions would be appreciated. I just want to know if this setup will be successful.
Thanks!
