RE: RC Snowmobile Polaris Fusion 900 Build Thread
Well i have done some work.I built up a shock tower and i used the front end parts from a stampede.I used the front bulkhead and cut it in half then cut it down to mount to the plate on the bottom of the body.This makes mounting all the other front end parts a lot more easy.I mounted the camber links to the inside of the "fender"and it is atatched to the rear servo mount,so it is strong.I used some threaded rod to make up the steering links and i enlarged the holes in the body so the won't rub.You can see in the pics how i mounted the servo,it is pretty straight forward.I used some spacers under the front bracket, 1/4 inch.I have front stampede shocks they are shorter than the rear and seem like they will work out.I have a 12t motor in there with a 18t pinion just for testing and it moves along pretty quick in the living room.
I will be building some rails for my track skid with some aluminum i have.I'm useing some roller wheels for sliding glass dors as bogie wheels.I'll see how it comes out
