RE: Jittering throttle and rudder servo WITHOUT engine running
Wy8e, I always do this and always have (I'm actually anal about the order), but thanks for chiming in! This happens after Tx is turned on, then Rx.
BigTim, I intially thought that the pushrods might be the problem, but I used the stock plastic pushrod that came with the kit.
Ken, I think actually learned the antenna run method from you and Minnflyer, so I didn't think it could be cause for any interference.
I don't actually expect anyone to chime in with THE answer, but thought someone might have had or seen a similiar occurence. Thanks everyone!
