RCU Forums - View Single Post - Learjet .40 Build
Old 12-12-2008 | 09:40 AM
  #55
vupilot
Default RE: Learjet .40 Build
I'll look and see what manual I have when I get home tonight. I have also noticed several mistakes in mine. The dihedral when dry fit looks to be pretty close to the 1.25" the plans call for but I have not measured it. I'll clamp it and measure it and let you know.
Did yours fit well at the front of the wing where you then glue the mounting block to the front center section of the wing? Mine does not seem to have much wood to glue the block to and I'm worried about its strength. The fiberglassing of this area I guess should make it strong enough, just curious hows yours came out? Do you have any pictures of it?. Seems the only things to glue the block to are the leading edges and the two center #1 ribs. Doesnt seem like much to hold it.
