RCU Forums - View Single Post - low speed needle valve on OS 46 AX?
Old 12-12-2008 | 07:06 PM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: low speed needle valve on OS 46 AX?
ORIGINAL: Stixoz
My best guess is that is the tiny flat head screw that is set inside the bolt that holds the throttle arm on, is that right?
This is absolutely correct. However, don't make any adjustments to the low speed needle until you absolutely are sure you have to. I have 6 of these engines and I can't remember making a low speed needle adjustment on any of them. In most cases you will find that they will run fine right out of the box needing no adjustments. Too many people starting out in the hobby will start twisting the low speed adjustment when it's something else that's actually the problem.
Ken
