RCU Forums - View Single Post - low speed needle valve on OS 46 AX?
Old 12-12-2008 | 10:51 PM
safeTwire
Default RE: low speed needle valve on OS 46 AX?
Turn the "bleeping" LS needle in or out a little at a time as needed until the engine transitions smoothly from low to high throttle. Adjust main needle once again. Not a good idea to takeoff until the engines right. Case Closed!
Pristine piston rings aren't going to do you much good, when your plane is smashed to smithereens!
