RE: BH T-28 Assembly
The trouble I see with the smaller strut is it will not accept the wheels that came with the model, much less larger ones and should work with the wire size on the model. The 120 size strut will but then needs a larger wire diameter. Either adds a lot of weight unless you can save a similar amount of weight by the wire you remove.
I'd also think twice the shock travel would be beneficial too.
Regards,
Clay
