RE: CMP 160 sized Texan
jojo....check post #283 I have posted pics..of the flaps and the 3 piece wing...you can see the bolt holes drilled through the top of the wing , through the wing tubes and into a T-nut mounted under the bottom skin...I removed some wing skin at the top and bottom of the wings and inserted and epoxied hard wood blocks above and below the aluminum wing tube for strength. like I said over 200 flights no problem....
