RE: Fuel proofing firewall - fuel lines
Gray Beard,
So you suggest not applying the epoxy or surfacing resin while the lines are installed in the holes? That makes sense, I guess I was just worried that the resin would build up in the holes in the wall and not allow me to pull the lines through. Maybe while the resin is setting up, I can run a few Q-tips around in the hole to wick up any residual liquid.
Curtis
