RE: HELP/ Centering Engine on Firewall
A good way to find the center of a circle is to draw diameters in a bunch of directions/angles (if you measure across, the widest point point is the diameter). They will intersect at the center of the circle.
A pictorial idea would be like cutting a pizza. If all cuts are across the widest part of the pie, the slices will all meet in the center.
