RE: Fuel proofing firewall - fuel lines
Yeah, that is my concern, I want to be able to put the tank in and make sure that if any raw fuel runs around in the engine compartment, it doesn't leach into the area where the tank is and weaken the wood there. I don't want to put it in and take it out all of the time, but I need to pull it in from the back(4* 40) and I expect it to be pretty tricky if the fit is tight. I forgot that Ii could just use a little silicone around the lines.
Thanks for the responses,
Curtis
