RCU Forums - View Single Post - BH T-28 Assembly
Old 12-16-2008 | 06:03 AM
  #313
Warbird Joe's Avatar
Warbird Joe
Default RE: BH T-28 Assembly
ORIGINAL: JimO
Clay, I agree with John, not sure why you needed the extra weight. My Original Saito 80 is close in weight to you 91 and I balanced on the mark with the batt under the servo's.
I also like to have my planes a bit nose heavy for initial flights so do tend to balance nose down. Tail heavy planes just don't fly well. With the big nose on this plane it will have tendency to slow quickly especially if you don't have adequate air flow out the bottom of the cowl. All this can add to a real anxious landing.
On you initial takeoff don't be in a hurry to lift off. Let it go on it's own and if the tail really squats, chop the power and let her settle back down.
JimO
I agree with John and Jim. Clay, if you recall I have the Magnum 91 2 Stroke. My electronics and battery is the Spektrum Channel Receiver and the Spetrum Battery. Pretty much standard size 4 Cell type battery. It is sitting right is front of the servo tray. I had to add absolutely no weight at all and the plane is just a tad nose heavy. I would check to make sure you are checking the balance in the right spot.
