RE: BH T-28 Assembly
Warning! Critical weak glue joint[:@]. The tabs that the servos mount to on the wing servo hatches are very poorly glued. Hot glue was used after the the tab was inserted in the hatch. One of mine broke loose when I touched it and the others all came out with little pressure. I used 30 min epoxy to glue them back in after cleaning off the hot glue. I suggest you check those joints or you might find your servos coming loose in flight[>:].
Bruce
