RCU Forums - View Single Post - RFI shielding
Old 12-16-2008 | 09:31 PM
captinjohn
Default RE: RFI shielding
ORIGINAL: coronabob
Super fast discharge/spark generates harmonics and ringing in a non-resistor plug. The resistance softens the discharge (slower di/dt) and thus no radio interference to speak of. Metal to metal rubbing is the culprit, not the ignition itself.
Some time ago I spent half a day looking for radio interference sources. I used an oscillator to trigger the CDI in lieu of a hall sensor on our engine. I had the spark plug laying on the bench sparking away. With the 'antenna' near enough to almost touch the spark itself or anywhere near the CDI board, I saw zero, nil, nata, nothing that would register on my digital phosphor scope. The 'receiver' was a germanium diode/LC tank. However, when I rubbed/scratched a screwdriver tip on something metal nearby I would pick up beaucoup noise even feet away from the antenna.
I mentioned the copper paint just because someone asked. In other words, I do not believe shielding any box will buy anyone anything in our gassers. Getting rid of metal rubbing contacts and minimize engine shakes will eliminate our woes.
Does this mean we have to install ceramic bearings and teflon coat the piston? Capt,n
