RCU Forums - View Single Post - YS 120NC Runs rough?
Old 06-02-2003 | 10:14 PM
Dave Shadel
Default YS 120NC Runs rough?
Leaning the reg will just screw up the transition. The bleed hole in the carb barrel (remove it and you'll see) will need to be drilled out slightly. Go a little at a time until the idle is OK. They are all different so I can't tell you exactly what drill size to use.
