RCU Forums - View Single Post - How C.G. affects flight characteristics?
Old 12-16-2008 | 11:33 PM
Lnewqban's Avatar
Lnewqban
Default RE: How C.G. affects flight characteristics?
Very well described, gaRCfield!!
I would add that the vertical location of the CG respect to the center of pressure created by the fuselage and the rudder may create a torque around the thrust axis that will add to the coupling effect.
Hence, moving the battery up or down, if possible, could help in a better KE.
Also, the highest the propeller thrust, the easier the KE, because of the vertical component; a propeller of bigger diameter and lower pitch would also help.
Regards!
