RCU Forums - View Single Post - Ali in Kuwait
Old 12-17-2008 | 03:40 AM
  #95
schroedm's Avatar
schroedm
Default RE: Ali in Kuwait
Hi Q8,
Yes, gear works fine now. I also have 3 large tanks and I pump to 130psi. I always cycle the gear once on the ground before i start the turbine and then pump back up to 130psi. This ensures all my airlines are primed with air so when I take off I know there is no big delay with the system being primed. This is caused by the valves I use dumping all the air in the airlines when the RX is switched off.
I'm thinking of more power and bigger tanks.
What turbine is in yours? Do you have a picture of your tank setup too??
Cheers
Mark
