RCU Forums - View Single Post - rx18 full fire mod
Old 12-17-2008 | 03:40 PM
bubbajoexx's Avatar
bubbajoexx
Default RE: rx18 full fire mod
ORIGINAL: blitzkrieg65
Bubba,
This looks great, but can you help me wrap my mind around it! What wires are you eliminating? When you do the upgrade, does it not function the same as the factory tank why? Or is this reffering to the mod that gets the left stick and the K button to fire together?
The Blitz
what this mod dose is removes the wires that are needed to engage the high tension flash as for the flash to work it requiers a signal from the recoil unit this removes the need for those wires and engages the cannon sound and fires the IR led as well the IR only fires when the recoil is attached this removes that need as well as the upward movment of the stick will egage the fire sound as well without it you can only get the IR led to fire using the K button on the remote . If upgreding to an rx18 board on a airsoft tank this allows the IR to fire when you fire the main gun
as to the other post this will not harm the board if soldered in correctly or you use the alternative method what you are doing with this mod is suppling the ground signal to triger the funtion of the K button and the ground signal normaly supplied by the recoil unit and you have 2 less wires going into the turret
