RE: Nitro Planes EDF Pre-Maiden Procedures
Re: Prop
Well you would need a smaller prop and it would be spinning like a little bee!
Remember what is happening is that the motor is spinning the current prop so fast that a large part of the blade is fully stalled.
You could probably drop the existing prop diameter about 1" or more and also the prop pitch by a number or two.
This would increase the efficiency.
Frankly that motor is better suited to a gear drive with a 2:1 reduction.
If you did that you could run the same or a larger prop to give you more thrust.
Post a picture of how you have it mounted if you can.
It may be possible to use an in-line gear drive depending upon the mount.
