RCU Forums - View Single Post - FEJ Rafale pics
Old 12-17-2008 | 09:12 PM
joeflyer
My Feedback: (49)
Default RE: FEJ Rafale pics
I would also remove the half bypass that is just aft the turbine, there's not enough clearance and you may run hot and loose power.
I believe you are referring the heat shield. On My FEJ F-16 I replaced it with one I made out of thin aluminum, which is much more effective. I have about 3/4" to 1" clearance between the shield and the turbine case all around. There is also room for some airflow over the top of the shield.
Joe
ID:	1091800   Click image for larger version
ID:	1091801   Click image for larger version
